VISA Calls Crash LabVIEW on RHEL and CentOS
Updated May 3, 2018
  • LabVIEW Professional
  • LabVIEW Base
  • NI-VISA
Programming Language
  • LabVIEW G
Other
  • RHEL 7
  • CentOS 7
LabVIEW development environment crashes every time the program uses an NI-VISA function or when an NI-VISA function is placed on the Block Diagram. LabVIEW built executables also crash when executing NI-VISA functions.
  1. LabVIEW crashes when launched from the terminal and the following will be printed to the terminal.
libnipalu.so failed to initialize
Perhaps you need to run updateNIDrivers
  1. ​If this is the case, first install NI-VISA 17.5 or newer
  2. If LabVIEW still crashes after this, run updateNIDrivers from a terminal and you shoud see the following.
ERROR: Error locating kernel sources for the requested kernel version
  1. If you do see the above, install the kernel-devel.x86_64 package for your specific kernel version.
  2. Run updateNIDrivers
