Rendezvous Step in TestStand Timing Out
Updated Apr 2, 2026
  • TestStand
I am trying to use the Rendezvous synchronization object in TestStand, but at the Rendezvous point in my main sequence, TestStand times out.
The total number of Rendezvous points should equal the value in the Number of Threads Per Rendezvous field in the Create Rendezvous step marked as Create.  If the number of threads never equals the value in Number of Threads Per Rendezvous, TestStand will time out.
Ensure that sub-sequences you are planning to synchronize also have a Rendezvous point.
