Does My cRIO Have Acronis Backup Software Installed?
Updated Feb 8, 2018
  • cRIO-9081
  • cRIO-9082
Other
Acronis True Image
I want to be able to see if my cRIO has Acronis software installed on it. How can I see if it is installed?
Acronis can only be installed on a cRIO using Windows Embedded which is possible only on the cRIO 908x series. So if you are not using a cRIO 908x running Windows embedded, then you do not have Acronis software installed on your cRIo.
If you are running Windows Embedded on your cRIO 908x, then Acronis software can be found with all other installed software in the 'uninstall or change a program' section of the Windows control panel.
