Yellow Exclamation Mark Next to My Build Specification
Updated Jan 8, 2019
  • LabVIEW Professional
  • LabVIEW Base
When I open up a saved project I see an exclamation inside of a yellow triangle appear under Build Specifications in the project explorer. When I right-click on the build specification and select Explain Warning I receive an error message pictured below that states I don't have a plug-in installed. How do I fix this error and what plug-in is missing?
This error means that you need to install and/or activate the LabVIEW Application Builder Toolkit. This is the "plug-in" that the message is referring to.
This message can appear if you have a project with a saved build specification and you open it on a computer that does not have LabVIEW Application Builder activated. You need to purchase and/or activate LabVIEW Application Builder in order to use your build specifications.
