Measurement Studio integration includes project wizards, the Add/Remove Class Library Wizard, the Parameter Assistant, and the DAQ and Instrument I/O Assistants. You also will not have the Measurement Studio menu item in your Visual Studio environment.
This KnowledgeBase article contains more information about how to use Measurement Studio without Visual Studio integration.
Also, if you choose to install Visual Studio integration during your setup, you may get an error message like the one below:
