For NI-DAQmx Base 2.2 and previous: In order to switch the firmware back to be compatible with NI-DAQmx Base 2.2 or previous, you will need to have a Windows machine with both NI-DAQmx 7.5 (or later) and NI-DAQmx Base 2.2 (or previous) installed. To re-associate the USB device to NI-DAQmx Base and to switch the firmware, follow the instructions in
Using a USB-6008 / 6009 / 6501 in MAX, and Switching Firmware Between NI-DAQmx and NI-DAQmx Base.
For NI-DAQmx Base 3.0 and later: Once the USB device is associated with NI-DAQmx Base, the lsdaq (NI-DAQmx Base List Devices) utility may alert you with a message that the device firmware is incompatible. For instructions on how to re-associate the USB device with NI-DAQmx Base, refer to steps 1-6 in
Using a USB-6008 / 6009 / 6501 in MAX, and Switching Firmware Between NI-DAQmx and NI-DAQmx Base. To update the firmware, you can run the firmware download utility installed with NI-DAQmx Base 3.0 and later (instructions below).
Instructions for updating the firmware on your USB device to work with NI-DAQmx Base 3.0 and later using the USB Firmware AutodownloaderThe USB Firmware Autodownloader utility will allow you to install the appropriate firmware to use with your NI-DAQmx Base 3.0 or later. This utility is installed with NI-DAQmx Base 3.0 and later at the following default location:
C:\Program Files\National Instruments\NI-DAQmx Base\bin\FWUpdate.exe and also included below as an attachment.
- Plug in the USB device(s) that you want to update.
- Run the utility from the location specified above :
-If your device(s) do not show up, click Refresh Device List
-If your device(s) still do not show up, check that your device(s) are associated with NI-DAQmx Base by following the relevant steps in Using a USB-6008 / 6009 / 6501 in MAX, and Switching Firmware Between NI-DAQmx and NI-DAQmx Base. - For each USB device recognized by the utility, a message will appear indicating whether the firmware needs to be updated in order to work with the version of NI-DAQmx Base you have installed
- If you need to update any firmware, place a check in the box next to the device(s) that you want to update
- Click Update Firmware to begin the update process, which can take up to a minute to complete depending upon how many devices are being updated
- Once the LEDs on the USB device(s) are blinking, you should see your USB device(s) show up in the utility with updated status messages.
-If your device(s) do not show up, click Refresh Device List - Once the update is complete, click the Exit to close the utility
A video tutorial detailing the above procedure is available at How to Update Firmware on the NI USB-6008/6009 for Use with the DAQmx Base Driver 3.X or Later.
