For most NI DAQ cards, a Push-Pull quadrature encoder is recommended since Multifunction DAQ card works best when it is constantly driven. The Push-Pull configuration does not float, it is always supplying
Vcc or ground, which is why it will work best with a Multifunction DAQ card.
If you are working with an Industrial I/O Card, check the user manual for the best quadrature encoder type.
Line DriverA line driver is a sourcing output. When in the on state, a line driver will supply Vcc. In the off state, a line driver will float. Because of this, a sinking input is required for proper operation. Please refer to the table below for a simple example of a line driver.
Open CollectorAn open collector is a sinking output. In the on state, an open collector will supply a path to ground. When in the off state, an open collector will float. For proper operation, a sourcing input is required. Please refer to the table below for a simple example of an open collector.
Push-PullA push-pull output is a combination of a line driver and an open collector. In the off state it will supply a path to ground and in the on state it will supply Vcc. Please refer to the table below for a simple example of a push-pull output.
