Archived:Windows SDK Error (-12) when Installing LabVIEW on Windows 7
Updated Feb 5, 2018
National Instruments does not actively maintain this document.
  • LabVIEW Professional
  • LabVIEW Base
I am trying to install an older version of LabVIEW (8.6, 8.5, etc) on Windows 7 and receive the following error when installing:
*** Error: Windows SDK function returned an error. (Error Code -12).
Only LabVIEW 2009 and later are officially supported on Windows 7.  However, some older versions of LabVIEW work with Windows 7.
The error message *** Error: Windows SDK function returned an error. (Error Code -12) can occur if you install LabVIEW from the main Setup.exe file that is executed with Autorun after you have put the CD/DVD into your PC.
In order to prevent this error from occurring, first try to manually run the Setup.exe located in the top level directory of the CD/DVD. If that does not work, you can try installing LabVIEW and additional modules/toolkits from their individual setup.exe files located on the CD/DVD in the Distributionsdirectory. For example, if you are only installing LabVIEW 8.6.1, the file path will be as follows:D:\Distributions\LabVIEW861\setup.exe (assuming the D Drive is the location of your CD/DVD) .
Note: The file path for setup.exe may differ depending on the distribution you acquire. For example, there may not be a Distributions folder if you acquired the media from a third-party.
