Causes of an "Unexpected Error" from Measurement & Automation Explorer (MAX)
Updated May 31, 2023
While using the Measurement & Automation Explore (MAX), an Unexpected Error dialog similar to the one below pops up. What are these exceptions? Is it safe to ignore them by selecting the Do not show this error again option?
MAX has the ability to detect exceptions thrown by internal plug-ins. Some of the exceptions are benign and do not negatively affect normal operation in MAX.
If this is the first time you've seen this error, restart your computer first. The error sometimes occurs after installing new NI software and not restarting the PC.
Here is a list of the current known exceptions. If the exception is benign and does not negatively affect your system, you may select Do not show this error again in the error dialog to prevent it from displaying again.
# Plug-In ExceptionBenign?
1NI-DAQmxCpcCopierProxy::GetSourceItemsIfNecessaryYes
Can occur when you import a .nce file to a remote RT target. Upgrade to NI-DAQmx 9.0, or later, to resolve.
2niFPui.mxxCmxRSFrameworkObserver::NotifyObjectRemovingYes
Can occur when you delete multiple FieldPoint targets.
3niVISAui.mxxCmxAggregateItemUI::GetPopupMenuYes
Can occur when you highlight/click a VXI instrument in MAX.
4imaqcfgui.mxxCmxAggregateItemUI::FinalReleaseNo
Can occur when MAX is closed. If MAX is upgraded from 4.6.2 or earlier to 4.7 and NI-IMAQ is not upgraded, this exception will be returned. Upgrade to the latest version of NI-IMAQ to resolve.
5niHDVUI.mxxCmxProviderWrapper::InitializeNo
Can occur when opening MAX. If MAX is upgraded from 4.6.2 or earlier to 4.7 and LabVIEW DSC is not upgraded, this exception will be returned. Upgrade to LabVIEW DSC 2010 or later to resolve.
6nipalsys.dllCmxSysExpertManager::InitializeExpertNo
Can occur when opening MAX. This exception will be thrown (in addition to other possible errors) on systems with Physical Address Extension enabled. See NI Software Fails When Physical Address Extension is Enabled to resolve.
7niPXIui.mmxCMXAggregateItemUI::GetViews, CPXIObject::FindParentNo
Can occur with PXI Platform Services versions before 3.0 and is related to an inability to load all or some parts of configuration for PXI chassis. Update to PXI Platform Services 3.0 or later to resolve.
This error can also occur if software was not installed properly or is corrupted, and can be fixed by reinstalling. Follow this article to Force Reinstall Non-Working or Corrupt NI Software , or remove DAQmx and all dependencies and install the software after a restart. A common cause of unclean software installs is having anti-virus software, so make sure to disable anti-virus.
This error is similar to another error that occurs when upgrading to NI-DAQmx 18.0 or 18.1 while using a real or simulated FieldDAQ device. See Internal Warning when Upgrading to NI-DAQmx 18.0 or 18.1 with FieldDAQ for more information on how to resolve this issue if you encountered this issue after upgrading to NI-DAQmx 18.0 or 18.1.
