You must make sure that the version of VeriStand in which you are developing is exactly the same version of the VeriStand support on the target.
If the VeriStand version is different in the host computer than the version in the RT target, you can follow this article:
Installing Different Versions of Software on My Real-Time Target upgrading NI VeriStand RT Engine.
