The
#pragma pack command is a preprocessor statement that can be used to specify the maximum alignment factor in LabWindows/CVI™. This behavior was added in LabWindows/CVI™ 4.0.
Below is code creating two structs to compare normal behavior with
#pragma pack.
struct {
char a;
short b;
char c;
} s1;
struct {
short x;
char y;
char z;
} s2;
p = sizeof(s1);
q = sizeof(s2);
In LabWindows/CVI™ 3.1 the values of both p and q will be 4.
s1: 1 byte (char) + 2 bytes (short) + 1 byte (char) = 4 bytes (structure), so p = 4
s2: 2 bytes (short) + 1 byte (char) + 1 byte (char) = 4 bytes (structure), so q = 4In LabWindows/CVI™ 4.0 and later you can use the
#pragma pack preprocessor statement to define the maximum alignment value for storing members of a structure in memory. When you use
#pragma pack(n) -- where n can be 1, 2, 4, 8, or 16 -- each structure member is stored with an alignment equal to the value of n or the byte size of the member type, whichever is smaller. If you use
#pragma pack without an argument, then structure members are packed according to the compiler's default value.
Here are the results in LabWindows/CVI™ 4.0.1:
#pragma pack (1) p = 4, q = 4;
#pragma pack (2) p = 6, q = 4;
#pragma pack (4) p = 6, q = 4;
Why are p and q the same in the 2nd and 3rd case?The only difference between structures s1 and s2 is the order in which the variables are declared. Here are the cases:
Using #pragma pack (1)In this mode, LabWindows/CVI™ will pack the structure members on every 1 byte boundary, meaning that there will be no padding between members in the structure.
Using #pragma pack (2)In this mode, LabWindows/CVI™ will pack on every 2 byte boundary or on the structure member's size, whichever is smaller. This means that
char data types will pack on a 1 byte boundary and
short data types will pack on a 2 byte boundary. Structure s1 will pack in this order:
- char a packs on a 1 byte boundary, so s1.a is stored at byte 0, occupying 1 byte of memory
- short b packs on a 2 byte boundary, so s1.b is stored at byte 2 (which means there will be a 1 byte pad at byte 1), occupying 2 bytes of memory (byte 2 and byte 3)
- char c packs on a 1 byte boundary, so s1.c is stored at byte 4, occupying 1 byte of memory
Structure s2 will pack immediately after structure s1 and it will pack in this order:
- short x packs on a 2 byte boundary, so s2.x is stored at byte 6 (which means there will be a 1 byte pad at byte 5, added to the end of structure s1), occupying 2 bytes of memory (byte 6 and byte 7)
- char y packs on a 1 byte boundary, so s2.y is stored at byte 8, occupying 1 byte of memory
- char z packs on a 1 byte boundary, so s2.z is stored at byte 9, occupying 1 byte of memory
Thus, structure s1 will return a size of 6 and structure s2 will return a size of 4.
Using #pragma pack (4)In this mode, LabWindows/CVI™ will pack on every 4 byte boundary or on the structure member's size, whichever is smaller. This means that
short data types will pack on a 2 byte boundary, the same as using
#pragma pack (2).See the attached file (
pragma.zip) for an image (
pragma.gif), which displays the way these two structures are stored in memory.
