What is the Overrange of My C Series Module
Updated Jan 12, 2018
  • NI-9203
I'm using a C series module and I want to know what is the maximum overrange for this module. Where can I obtain that information?
When applicable the specification of the C Series Module include a Minimum overrange value, this specifies the minimum overrange that is guaranteed for the device, there's not a set or maximum value that can be guaranteed for every module of a particular model as there can be small differences in this value between modules.
A typical input span is given in the following document, this provides a typical estimated value for the overrange of some C series modules, this can be used as a reference but shouldn't be used as an official specification for the device.
Converting and Calibrating CompactRIO Analog Input Values (FPGA Interface)
