Serial VISA Read Terminates Before Specified Number of Bytes Has Been Read
Updated Apr 1, 2026
  • NI-VISA
  • VISA Read will return from reading after it receives a termination character, even if it has not yet received the number of bytes specified. Is there a way to circumvent this and read the full message, including any termination characters?
  • I need to configure serial communication using NI-VISA that is capable of reading 256 ASCII characters, where any termination characters are read as literals instead of terminating the read operation. How can I do this?
To continue reading a string even after a termination character is received, it is necessary to set the Termination Character Enable and Serial End Mode properties using a Property Node. Follow the steps below to implement this:
  1. Place a Property Node on the Block Diagram of your VI.
  2. Connect your VISA resource name to the Reference input of the Property Node.
  3. Right-click the Property element of the Property Node and click Change All To Write from the shortcut menu.
  4. Drag the bottom edge of the Property Node to reveal two property elements instead of one.
  5. Click the first Property element and select Messager Based Settings >> Termination Character Enable.
  6. Right-click this property and select Create >> Constant. Ensure this value is set to False (which it is by default).
  7. Click the second Property element and select Serial Settings >> End Mode for Reads.
  8. Right-click on this property and select Create >> Constant. Ensure this value is set to None.
    • By default, VISA sessions will use a termination character of line feed, 0x0A or \n.
The code snippet below is an example of a simple serial read and write using NI-VISA, where the properties described above have been configured to ensure that the full message (including termination characters is read):
