You can also access your device over FTP by using Windows' File Explorer directly. Do this by typing the IP address of your remote system directly into the address bar, e.g.
ftp:// 172.22.11.2/, using the example from above.
When an external CompactFlash, USB drive, or other storage device is connected to the Real-Time controller, if the controller is running Linux Real-Time (LinuxRT), a folder should show up with the letter U, V, or W, depending on the number of drives attached. For non-LinuxRT controllers, more information is located in
Accessing External Storage on a Real-Time Controller
