When I open Vision Builder for Automated Inspection (VBAI), it takes 3 to 4 minutes for the welcome page to show up. I Checked event system log and see the following error:
The description for Event ID 100 from source niZeroconfService cannot be found. Either the component that raises this event is not installed on your local computer or the installation is corrupted. You can install or repair the component on the local computer.
If the event originated on another computer, the display information had to be saved with the event.
The following information was included with the event:
864: ERROR: read_msg errno 0 (The operation completed successfully.)
The specified resource type cannot be found in the image file
