DAQ Device Fails Calibration After Adjustment
Updated Nov 7, 2018
  • Calibration Executive
When running a manual calibration procedure from NI's website or using Calibration Executive to calibrate a DAQ module, the module fails the calibration.  The module fails even after running the 'Adjustment' procedure meant to bring the device back within specifications.
Because the device cannot be adjusted to within specification, there is likely a hardware problem with the module.  Please contact NI Support to have the module sent in for repair.
