DAQmx Compatibility with USB-9215A
Updated Jan 11, 2018
  • USB-9215
What versions of DAQmx should I use with the USB-9215A?
The USB-9215A is compatible with DAQmx 15.1.1 and previous. You should also ensure that the version of DAQmx you are using is compatible with the operating system your computer is running, according to this chart
