Can I Save Multisim Files in My Current Version for Use in a Previous Version?
Updated Mar 2, 2020
  • Multisim
  • Ultiboard
  • I created or moved a file to a newer version of Multisim, but I would also like to save it for use with an older version of Multisim. Is there a way to save the file for use in a previous version of Multisim?
  • Can I open 14.1 Multisim files in Multisim 14.2?
Multisim files are not backwards compatible. For example, a file created in version 13 cannot be open in version 12 or previous, and there is no option to save files as a previous version.
On the other hand Multisim is forwards compatible, this means you can open older files in newer versions. For example, you can open a version 10 file in Multisim 13, regardless of the versions. Therefore it is also possible to open 14.1 files in Multisim 14.2.
The same rules apply to Ultiboard files.
