Note: NI will remove support for Phar Lap for cRIO in the NI 2020 Software Release and for PXI in the NI 2022 Software Release. For more information, please see the Phar Lap RT OS EOL Road Map. Also, NI does not plan to support Dual-Boot for NI Linux Real-Time controllers at this time.
- Due to differences in frameworks of Windows 10 and RT operating systems, PXIe controllers can not be dual booted with both Windows 10 and a RT OS.
- NI's policy for PXIe Controllers that ship with Windows 10 is that they are configured to boot in Unified Extensible Firmware Interface (UEFI) mode with a GUID Partition Table (GPT) partitioned hard drive. Windows 10 systems which are installed in UEFI mode with a GPT partitioned hard drive do not support dual booting PharLap RT, and there is no plan to add this capability. Hence, dual booting with Windows 10 is not supported with NI PXIe controllers. PharLap RT requires legacy booting and a Master Boot Record (MBR) partitioned hard drive.
- Configuring a dual boot Windows 10 PXIe Controller using MBR partitioned hard drive is not recommended by NI. NI is not responsible for any malfunctions of the PXIe controller.
- If you would still like to change between systems, it is recommended that you change out the physical hard drive of the controller with the operating system of choice loaded on the new drive. If your chassis originally had Pharlap RT installed, you may need to update the BIOS using a bootable USB to support the UEFI mode required with Windows 10.
