Initial Voltage Spike on Analog Output of USB 6002 Device
Updated May 3, 2018
  • USB-6002
I'm using an analog output signal from the USB and connecting it to the sound line in from the back of the computer. At the start of the acquisition, I see a voltage spike and then a slopping line before settling at the voltage I expect to see. How do I get rid of this?
This could be caused by several things
  • The power up voltage of this device is 0V. Thus, there could be a short voltage ramp up during startup which can cause the spike and then slow settling.
  • USB 6002 is one of the simpler DAQ devices so it has low accuracy.
A workaround of this would be to use a filter such as a Butterworth filter to only allow the expected signal to be shown.
