此內容不適用於您所偏好的語言。
此內容已顯示為其他適用語言。 您的瀏覽器可能含有可協助翻譯的套件。
Does My Camera Use NI-IMAQ, NI-IMAQdx or NI-IMAQ I/O?
Updated Oct 30, 2023
  • PCIe-8255
  • PCI-8254
  • PCIe-8254
  • PCIe-8237
  • PCIe-1473
  • NI-1483
  • NI-IMAQ
  • NI-IMAQ I/O
  • NI-IMAQdx
  • I have downloaded and installed NI Vision Acquisition Software (VAS) but I see multiple drivers listed during installation. Does my camera or image acquisition device use NI-IMAQ, NI-IMAQdx, or NI-IMAQ I/O?
  • What is the difference between NI-IMAQ, NI-IMAQdx and NI-IMAQ I/O?
  • Which VAS driver is suitable for my camera?
The NI-IMAQ, NI-IMAQdx, and NI-IMAQ I/O are driver packages automatically installed by NI Vision Acquisition Software (VAS) for use with different image acquisition devices. Each driver includes a set of LabVIEW VIs that can be used for high-level control.
NI-IMAQ
The NI-IMAQ driver software supports National Instruments hardware only and is needed to use the following image acquisition devices:
  • National Instruments Camera Link Frame Grabbers*
  • National Instruments Parallel Digital Frame Grabbers
  • National Instruments Analog Frame Grabbers
  • National Instruments 17xx Smart Cameras
NI-IMAQdx
The NI-IMAQdx driver software is needed to use third-party image acquisition devices which use the following buses and standards:
  • Gigabit Ethernet Cameras Supporting GigE Vision
  • FireWire IEEE 1394 Cameras
  • USB 2.0 Cameras Supporting Microsoft DirectShow
  • USB 3.0 Cameras Supporting USB3 Vision
NI-IMAQ I/O
The NI-IMAQ I/O driver software is a smaller driver API used exclusively to program the National Instruments Vision RIO image acquisition cards including the following cards:
  • NI PCIe-8255R
  • NI PCI-8254R
  • NI PCIe-8237R
  • NI PCIe-1473R
  • NI PCIe-1473R-LX110
  • NI 1483 FlexRIO Adapter Module
Note: The National Instruments Vision RIO cards will require both the NI-IMAQ and NI-IMAQ I/O drivers.
*In later versions of VAS, Camera Link Frame Grabbers can use IMAQdx as well
VAS also includes libraries for programming in C, C++, C#, Visual Basic, and Visual Basic .NET.
