NI-DAQmx Base to NI-DAQmx Conversion Utility
Updated Jun 27, 2019
I have an existing LabVIEW data acquisition application written with NI-DAQmx Base that I would like to port to NI-DAQmx. Is there an easy way to do this?
There is a utility that will convert LabVIEW applications written using NI-DAQmx Base to use NI-DAQmx. You can download it from this link:
DAQmx Base is compatible with Windows XP, Windows Vista, Windows 7, and Windows 8.
