Change the Coupling Mode for My DAQ or DSA Device
Updated Nov 17, 2020
  • LabVIEW Base
  • LabVIEW NXG
  • LabVIEW Professional
My device specifications say that the coupling mode is software selectable. How can I change the coupling mode between AC, DC, and GND coupling?
You can do this using DAQmx Channel Property Nodes:
  1. Place a DAQmx Channel Property Node on your block diagram in LabVIEW.
  2. Choose the property to be Analog Input > General Properties > Input Configuration > Coupling.
  3. Right click on the Property Node's input terminal and select Create > Constant.
  4. Change the value of the constant enum to the coupling mode you required.
To set individual channels as AC or DC coupled under one task, refer to Example Program: Programmatically Setting AC and DC Coupling for Individual Channels on one DAQmx Task.
In general, only S Series and Dynamic Signal Analyzer (DSA) devices have software selectable coupling modes. Coupling is strictly DC for other devices (such as X Series multifunction DAQ). Attempting to set AC coupling for a device which does not support it will result in "Error -20077: Requested value is not a supported value for this property"
See DAQmx Task Gives Error -200077 When Creating a Custom Scale for more information. Refer to the user manual and specifications for your device to make sure that this feature is supported.
