Display Current Time in LabVIEW VI
Updated Jun 13, 2022
  • I would like to display the current time in my LabVIEW VI.
  • How do I create a software-timed millisecond timestamp in LabVIEW?
You can display the current time using a timestamp in LabVIEW. This can be written in your application using the Get Date/Time In Seconds VI as shown below:
Furthermore, you can format the Date/Time as a string so that you can easily transfer that timestamp into other programs (text or .csv files).
You can format the timestamp to include date and time information based on your application's needs (like complete date, milliseconds, etc.). Use the Format Date/Time String VI to determine the syntax of your timestamp data.
  • The default timestamp format is %m/%d/%Y%H:%M:%S.
  • For example, if you wanted to include the milliseconds, you would append a %3u to the end of the string: %m/%d/%Y%H:%M:%S%3u.
