RS-485 Pins for 2- and 4-Wire Transmission
Updated Aug 1, 2023
  • RS-422/RS-485
  • Serial Cable
  • PXI-8433/4
  • PXI-8433/2
  • PCI-8433/4
  • I am using RS-485 serial communication, what pins do I need to connect for 2- and 4- wire transmission?
  • What are the digital output pins on the RS-485 port to communicate with another device?
Full Duplex (4-Wire)
For 4-wire transmission, you will need to wire the following signals together from the master to slave device:
The corresponding pins will depend on your device’s user manual and the RS-485 cable connector type. For NI serial hardware connector pinout diagrams, refer to the Serial Quick Reference Guide.
Half Duplex (2-Wire)
For 2-wire transmission, you will need to short the transmit (TXD) and receive (RXD) signals together on the RS-485 port. Refer to Set Up 2-Wire (Half-Duplex) Communication with RS-485 Port for the pinouts and more details.
NI-Serial directly supports 4-wire full duplex operation on peer-to-peer RS-485 networks. Multidrop RS-485 networks require additional software development. For cabling solutions, refer to NI Serial Cable  product page.
To prevent reflections for both 2- and 4-wire transmission, you must properly terminate the transmission lines. For more information, refer to RS485 Termination.
