In previous versions of TestStand, however, the expression needs to be expanded to reflect the same functionality. Let's construct an example where the
Select step expression is
Locals.x. For a Case step to execute with the the values
5, 6, 10, 20, the expression would look like the following:
Locals.x == 5 ? 5 : Locals.x == 6 ? 6 : Locals.x == 10 ? 10 : Locals.x == 20 ? 20 : NAN
Take a look at
this TestStand help page for information on the ?: conditional operator. Also, note that the use of
NAN in the above expression has a caveat. If your code allows for
Locals.x to ever be set as
NAN (maybe due to an unexpected mathematical result), this case can be undesirably executed. As an alternative, you can use another number, such as
-1 or
INF, if you never expect
Locals.x will be set to those values.
