Why Is the NI_ChannelLength Property Not Found in My TDMS File?
Updated Sep 20, 2022
  • LabVIEW Base
Other
LabVIEW 2017 - 32 bit
Windows 7 -
I have a TDMS file that I want to know the length of without loading it into memory by performing a TDMS Read. I have tried using the TDMS Get Properties function and wired the property names input as NI_ChannelLength. However when I run the function, the Found output returns False. How do I get the channel length of my TDMS file?
The NI_ChannelLength property of a TDMS file is created and populated during the generation of the TDMS file. If this property was not created and populated during the creation of the TDMS file, the TDMS Get Properties function will return a False for the Found output because the property does not exist. This often happens when the TDMS file was converted from a different file type.
