Unexpected Hardware Error with PXIe-6570 when Bursting Pattern
Updated May 3, 2018
  • PXIe-6570
  • When I burst my pattern in the Digital Pattern Editor, it will continue to burst until I press the abort button
  • The Access and Active lights on the PXIe-6570 are behaving as expected described by the PXIe-6570 Getting Started Guide
  • When I press the abort button, I get an unexpected hardware error
Make sure you have a halt opcode at the end of your pattern file.
For more information, take a look at the SPI Flat Register IO.digipat file within the SPI Register IO example. You can find this example in the Digital Pattern Editor environment through the Learning tab and selecting Digital Pattern Editor Examples>>SPI Register IO.
