Il contenuto non è disponibile nella lingua selezionata.
Verrà mostrato il contenuto in un'altra delle lingue disponibili. Il tuo browser potrebbe avere delle funzionalità di traduzione.
Setting LabVIEW VIs to Open in Run Mode
Updated Jan 18, 2023
  • LabVIEW Base
  • LabVIEW Professional
I want my VIs to be running when I open them. How do I configure my LabVIEW VIs to open up in Run Mode instead of Edit Mode?
Below you will find the different methods to change this setting according to your LabVIEW version.
LabVIEW 2009 and newer: The setting to open VIs in run mode can be found in the VI Properties. You can access this option by browsing to File » VI Properties » select Execution from the Category drop-down menu » check Run when opened from the list of options as seen in the screenshot below.
LabVIEW 8.0: Open LabVIEW and browse to Tools » Options » Environment and check/uncheck Open VIs in run mode as seen in the screenshot below.
LabVIEW 6.x - 7.x: Open LabVIEW and browse to Tools » Options » Miscellaneous and check/uncheck Open VIs in run mode as seen in the screenshot below.
A VI can enter Run Mode by:
  • Clicking the Run or Run Continuously buttons on the front panel toolbar
  • Clicking the Single Stepping buttons on the block diagram toolbar.
  • Pressing Ctrl+M or browsing to Operate » Change to Run Mode
When a VI is in Run Mode, neither the block diagram or the design of the front panel can be edited or modified. Some menu items are unavailable while a VI is in Run Mode. Setting your VIs to open in Run Mode may be desirable if you want to keep the application in VI format (as opposed to an executable) but don't want the user to accidentally modify the VI.
