Note: Refer to
Calling Shared Libraries for more information about using external code in LabVIEW. In LabVIEW 7.1 or earlier, refer to the
Using External Code in LabVIEW manual (linked below) for more information about using external code in LabVIEW.
National Instruments IEEE 1394 (FireWire) and USB hardware devices are supported through standard National Instruments driver interfaces such as NI-DAQ.
Note: Although USB contains the word serial, it is not the same serial protocol used in RS-232. Therefore, you cannot use the Non-VISA Serial VIs or functions to interact with a USB device. Any bus protocol, including USB and IEEE 1394 (FireWire), should have a well-defined interface for the user because device manufacturers do not want users to have unrestricted access to memory locations on the bus.
