How Do I Publish My VI to a Web Page?
Updated Nov 19, 2019
  • How do I publish my VI so that I can control or view it's front panel from a web page?
  • How do I view and control front panels on a web browser?
  • How can I access a VI on a web browser?
To view or control a VI on a web browser, a Web Sever must be configured appropriately and a HTML file must be generated.
The following steps show how this can be done:
1. Open LabVIEW and navigate to Tools»Options»Web Server.
2. Under the Remote Panel Server section, check Enable Remote Panel Server.
3. Under the Visible VIs section, enter the name of the VI in the Visible VI field and press the Add button.
  • By default, all VIs are set to visible.
  • Refer to Syntax for the VIs Lists for more information on entering VI list entries.
Note the following:
  • The control time limit specifies the amount of time (in seconds) that a remote client can control a VI when multiple clients are waiting to obtain control. The default time is 300 seconds. If Use default contains a checkmark, you cannot edit this field.
  • LabVIEW does not begin monitoring the time limit set on a particular VI until a second client requests control of the same VI. If a second client never requests control of the VI, the initial client never loses control of the VI.
4. Under the Browse Access section, enter the network name of the computer that needs to view the VI in the Browser address field and press the Add button. Ensure that the Allow viewing and controlling option is selected.
  • Similarly to the Visible VIs section, all browser addresses have access to the VIs by default.
  • Refer to Syntax for Browser Address Lists for more information on access list entries.
5. Exit out of the Options dialog box and navigate to Tools»Web Publishing Tool to open the Web Publishing Tool dialog box. Please note that the Start Web Server button should be disabled if all previous steps have been followed.
6. Under Select VI and Viewing Options section, browse to and select the desired VI. Ensure the appropriate Viewing Mode is selected and press Next
7. Start the LabVIEW Web Server by selecting Start Web Server, as shown in the image above. If it has not started, then the default port used for HTTP may be occupied by something else. To fix this, change the HTTP port number as shown in the image of step 2.
8. Under the Select HTML Output section, enter the desired document title and HTML content and press the Next button.
9. Under the Save the New Web Page section, select where to save the HTML file and choose the file name and press the Save to Disk button. To access the front panel, open this HTML file.
Note the following:
  • Even if you had enabled SSL, the URL will still show an http link. You just need to modify the link to say https instead of http and the correct https port number instead of the http port. After those changes are complete then the secure web page will work.
  • Sometimes there can be a certificate error when the certificate used was not digitally signed and is therefore not trusted.
Please note that it is necessary to use a compatible web browser to avoid a missing plugin error. A list of these browsers can be found in the Additional Information section of Why Do I Get a Missing Plugin Error When Loading a Remote Front Panel?
