Although you cannot run VIs directly from the LV Run-Time Engine, you can create an LabVIEW executable from a VI that can calls another VI dynamically through the
VI Server .
The dynamically called VI does not have to be compiled with the executable, but it needs to have properties and methods supported on the LabVIEW Run-Time Engine.
For example, the dynamically called VI will not be able to run if it includes
Block Diagram:Get Image Scaled Method since this is not supported on LabVIEW Run-Time Engine.
