Using Python to Run TestStand Sequence File
Updated May 10, 2018
  • TestStand
Programming Language
  • Python
Is there a way to call TestStand sequence file and retrieve the test status in a Python script?
NI TestStand provides a comprehensive ActiveX API, which can be used from any software development environment that supports access to ActiveX automation servers. To achieve this in Python you need to utilize the Pywin32 Python Module. Python Sample Code:
Executing MainSequence:
tsEngine = win32com.client.Dispatch('TestStand.Engine.1')
print('TestStand %s.%s ready' % (tsEngine.MajorVersion, tsEngine.MinorVersion))
sequencePath = 'C:\\Users\\Desktop\\Sequence File 1.seq'
seqFile = tsEngine.GetSequenceFileEx(sequencePath)
execution = tsEngine.NewExecution(seqFile, "MainSequence", None, False, 0)
execution.WaitForEndEx(60000)
print(execution.ResultStatus)
tsEngine.ReleaseSequenceFileEx(seqFile, 0x4)
It is also possible to execute a sequence file with process model and generate a report. Below is the sample code:
Executing Single Pass with Sequential Model:
seqFile = tsEngine.GetSequenceFileEx(​sequencePath)
procModel = tsEngine.GetSequenceFileEx('SequentialModel.seq', 0x20, 1)
execution = tsEngine.NewExecution(seqFile, 'Single Pass', procModel, False, 0)
tsEngine.ReleaseSequenceFileEx(procModel)
