Unable to Update Firmware of NI Linux Real-Time Device
Updated Apr 18, 2023
  • CompactRIO Controller
  • myRIO Student Embedded Device
  • NI Linux Real-Time
I'm using an NI Linux Real-Time device and I get message saying that I need to update the firmware of the device, but I can't find the files for the update as described in Upgrading Firmware on Linux Real-Time Device . How can I update the firmware of my device?
Update the version of your NI-RIO drivers to a version that is at least compatible with the latest version of LabVIEW you have installed. After you have updated the driver version follow the steps onĀ Upgrading Firmware on Linux Real-Time Device .
Firmware updates for NI devices are distributed with the device drivers. If there is a firmware update needed and the appropriate file is not found, updating the driver will provide the needed firmware file.
