Cannot add R Series Multifunction RIO Device to LabVIEW Project Explorer
Updated May 16, 2018
  • Multifunction Reconfigurable I/O Device
  • C Series Multifunction I/O Module
  • LabVIEW FPGA Module
  • LabVIEW Real-Time Module
  • NI-RIO
  • NI R Series Multifunction RIO
I have installed all software requirements mentioned in the getting started guide, and want to use R Series Multifunction RIO device in LabVIEW. But I can't add my device to the project. I install NI R Series Multifunction RIO device driver and know that it is compatible with LabVIEW version.
How can I add a R Series Multifunction RIO device device to LabVIEW project?
Check what driver version you are using.
Several NI hardware (CompactRIO, CompactDAQ, Single-Board RIO, R Series, and EtherCAT) requires not only device driver compatibility but also correspondence with LabVIEW and add-on modules.
Case 1:
NI R Series Multifunction RIO 17.0.1 is compatible with LabVIEW 2014 SP1, 2015 SP1, 2016, 2017, but LabVIEW compatibility of PXIe-7846R is LabVIEW 2016 or later.
Case 2:
NI PCI-7833R is not supported with the NI R Series Multifunction RIO 17.0 driver. The device supports LabVIEW and LabVIEW FPGA Module version 7.1 to 2016. Then, it must use NI-RIO 1.3 to NI R Series Multifunction RIO Device Drivers August 2016.
To check the compatibility of your device and software, refer to Software Support for CompactRIO, CompactDAQ, Single-Board RIO, R Series, and EtherCAT.
