Can I Connect to the Same cDAQ Chassis from Different VIs Simultaneously?
Updated Jan 5, 2018
Other
cDAQ Chassis
I am willing to use same cDAQ chassis in more than one VIs, which are required to run simultaneously. Is it possible?
Yes, you can use same cDAQ chassis in more than one VIs. Just make sure that you do not use same channel (or task) in more than one VI. If you are using different channels in different VIs and running simultaneously then there shouldn't be any problem.
