Create FFT Spectrograms in LabVIEW
Updated May 11, 2023
  • LabVIEW Base
  • LabVIEW Professional
  • LabVIEW Advanced Signal Processing Toolkit
I want to use LabVIEW to create FFT spectrograms. Are there any good resources available to do this?
You can create spectrograms using the Spectral Analysis VIs. A great community example program exists to help you get started with your first spectrogram.
Additionally, please check the NI Example Finder by opening LabVIEW and navigating to Help>>Find Examples and entering "spectrogram" in the search bar.
