このコンテンツは設定された言語で表示できません。
Configure Alias in NI MAX to Resolve Conflicts or Errors
Updated Nov 22, 2022
  • LabVIEW Real-Time Module
  • NI-VISA
When I try to change the VISA Aliases for my devices in Measurement & Automation Explorer (MAX), I get the following error:
The alias "<alias name>" conflicts with alias for the resource "<resource name>".  Please choose a different alias.
I do not see any other devices with this VISA Alias in MAX. Is there a way I am able to change the alias for my device?
There are multiple ways to change the VISA Aliases on your machine, see the options below:
  1. Look under PXI System in the Configuration window in MAX.
  1. Another way to do this is within the toolbar in MAX. Select Tools » NI-VISA » VISA Options. From the VISA Options window, choose Aliases under the General Settings section. You will now be able to Rename Alias, Add Alias, or Clear All Aliases. Once you have made the appropriate changes, select the Save button to implement the changes.
  2. If this still does not resolve the conflict, you can access aliases directly in your system by browsing to a configuration file called visaconf.ini. This file is typically located in one of the following locations:
  • Windows Vista or later: C:\ProgramData\National Instruments\NIvisa\visaconf.ini (note ProgramData is a hidden folder in Windows by default)
  • Windows XP: C:\Documents and Settings\All Users\Application Data\National Instruments\NIvisa\visaconf.ini
  • Windows 2000/NT: C:\VXIPNP\WinNT\NIvisa\visaconf.ini
  • PharLap ETS: ni-rt\system\vxipnp\WinNT\nivisa\visaconf.ini
  • NI Linux Real-Time: /usr/local/vxipnp/linux/NIvisa/visaconf.ini
