该内容不适用于您选择的语言
Note that changing PDO mappings requires editing EtherCAT slave-manufacturer-defined XMLs. As such, performing this manually is not officially supported and should be performed by the slave manufacturer instead.To change PDO mappings for third party EtherCAT you can follow the steps below:
Pay attention that there are a total of four Sync Managers in the .xml file. Two Sync Managers are responsible for coordinated SDO communication (Service data objects) and do not need to be modified to change the PDO mapping. The active Transmit (TX) and Receiving (RX) PDOs are controlled by two Sync Managers.The two sync managers controlling PDO communication must be changed in the .xml file to point to the correct PDO mapping. This is accomplished by moving the SM tag in the .xml file to the appropriate PDO mapping.
