Modular Data Acquisition
High-Performance Test
Note that changing PDO mappings requires editing EtherCAT slave-manufacturer-defined XMLs. As such, performing this manually is not officially supported and should be performed by the slave manufacturer instead.To change PDO mappings for third party EtherCAT you can follow the steps below:
