'OldVal' Property Returns an Incorrect Value Using Embedded UI
Updated Jan 9, 2019
  • LabVIEW Real-Time Module
  • NI Linux Real-Time
I am interactively running a LabVIEW Real-Time VI on a target with Embedded UI enabled. Why does the OldVal property in my Value Change Event Structure return an incorrect value?
This is a documented known issue with using NI Linux Real-Time with Embedded UI in LabVIEW 2014 or 2015. You can work around this by using a shift register to access the old value instead of the OldVal property node. The code snippet below illustrates this work around.
Note: You will not experience this behavior if you use a Real-Time executable, rather than an interactive VI on the target.
