CIP Error - CIP Extended Status: 0x311 with the EtherNet/IP driver
Updated Jan 9, 2019
  • NI-Industrial Communications for Ethernet/IP
When I communicate with a PLC using NI-Industrial Communications for Ethernet/IP, I get the following error:
Error -251723760
Details: CIP Error - Extended status may be available
CIP Status: 0x1 (Connection failure)
CIP Extended Status: 0x311 (Port not available)
Why do I receive this error?
If you mistakenly swapped the backplane port number and Logix slot number, you will get this CIP Error. The syntax for a simple system is <PLC address>,<backplane port number>,<Logix slot number>.
Example: 10.0.0.1,1,0 is the routing path for a ControlLogix 5561 with IP address 10.0.0.1 and with the processor in slot 0 of an AB-1756 4-slot backplane.
This error message is not to be confused with a TCP/IP port.  It actually relates to the slot configuration as specified in the network path parameter for an EIP Tag Read/Write VI terminal.
