Microsoft released an update that installs the Microsoft .NET Framework 4 Client Profile which provides a subset of features from the .NET Framework 4. This update is recommended by Microsoft for Windows Vista and Windows 7 operating systems. For more information on this update, refer to
The .NET Framework 4 Client Profile is available on Windows Update.
You may be experiencing this behavior if TestStand is unable to register the type library for the
TSDotNetUIControls.dll located in the
<TestStand>\Bin directory.
TestStand uses the latest version of
RegAsm.exe to register assembly type libraries. The .NET Framework 4 Client Profile update installs a version of the .NET Framework 4
RegAsm.exe which lacks the specific functionality that TestStand requires to successfully register its assemblies’ type libraries. If you have the .NET Framework 4 Client Profile update installed prior to installing a version of TestStand, the TestStand installer will not successfully register
TSDotNetUIControls.dll which leads to the error displayed in the Problem section of this article when using a TestStand User Interface. This problem does not affect the TestStand Sequence Editor.
