Why Does My DSA Device Take So Long to Self-Calibrate?
Updated Jan 3, 2018
  • PXIe-4497
  • PXIe-8135
  • PXIe-1082
I am self-calibrating all of the cards in my PXI system. The DAQ cards only take seconds to self-calibrate, but my DSA device takes 2-3 minutes. Why is the DSA device taking so long? Can I speed the process up?
This is expected behavior and there is no way to speed the process up. The reason that DSA devices take longer to self-calibrate is because it must calibrate over a wide range of frequencies. With DSA devices accuracy is a concern, whereas with DAQ devices there is a more of a focus on the actual voltage of the signal being calibrated.
