NI-DAQmx is National Instruments' current-generation data acquisition driver. You have to install NI-DAQmx which includes the DAQ API that allows you to develop instrumentation, acquisition, and control applications.
On the page
NI-DAQmx and LabVIEW Compatibility you can see supported versions of the NI-DAQmx hardware driver with LabVIEW. Reference this information to ensure you install the correct version when
Upgrading or Downgrading LabVIEW with NI-DAQmx. Using incompatible versions may result in errors, missing LabVIEW palettes or functions, or devices and tasks failing to show up in NI Measurement & Automation Explorer (MAX).
