Can I Build 64-Bit exe Using 32-Bit LabVIEW or Vice Versa?
Updated Apr 8, 2025
I want to build a 64-bit executable using 32-bit LabVIEW. Is that possible?
Alternatively, can I build a 32-bit executable using 64-bit LabVIEW?
You cannot build a 64-bit exe using 32-bit LabVIEW. Only 32-bit exe can be built using a 32-bit version of LabVIEW. To build a 64-bit exe, you will need to use a 64-bit version of LabVIEW.
Also, you cannot build a 32-bit exe using 64-bit LabVIEW. You would have to use the 32-bit version of LabVIEW to build a 32-bit executable.
