When I try to install LabVIEW™, VeriStand™, or other NI software, I receive one of the following (or equivalent) dialog boxes at the end of installation:
You must install the appropriate device drivers in order to add support for your hardware in LabVIEW. Even if you installed device drivers with a previous version of LabVIEW, you must install them again with the current version of LabVIEW to ensure hardware support.
Install National Instruments Device Drivers now? Insert the National Instruments Device Drivers CD to install now. If you want to install additional National Instruments software, or if you do not have this CD, you can install NI device drivers later.
At the bottom of either dialog box, there is the following message highlighted in red text:
The specified folder does not contain the correct volume.
What does this dialog box mean, and which option should I select?
