Changing Network Settings on ATCA
Updated Oct 16, 2018
  • ATCA-3671
  • LabVIEW FPGA Module
  • NI-ATCA FPGA Modules
  • NI-ATCA FPGA Modules 16.0
  • NI Linux Real-Time
Programming Language
  • LabVIEW G
Can I change the network settings on the ATCA?
Network settings on the ATCA can either be changed temporarily or permanently; the steps are listed below.
Note: Permanently changing the IP address has the possibility of creating an inaccessible system if you lose the address that the ATCA was changed to
For permanent changes after reboot:
  1. Connect to to our ATCA chassis as we would access the shell on NI Linux Real-Time device
Note:
  • The default IP address of the ATCA-3671 is 192.168.0.75
  • The for the user we should log into the root instead of admin
  1. Modify the file /etc/network/interfaces
  • After logging into the shell, mentioned in step one, you can run the command below to see the contents of the file
cat /etc/network/interfaces
  • The contents should look like the following:
# Wired interface
auto eth0
iface eth0 inet static
address 192.168.0.75
netmask 255.255.255.0
network 192.168.0.0
gateway 192.168.0.1
  • To modify the contents of the file you can use VI editor in the session
For temporary changes:
Note:
  1. Once logged into the device we can run the following commands to change the address
ip addr 10.16.33.220/23 dev eth0
ip addr del 192.168.0.75/24 dev eth0
