Archived:Can't See DAQ Assistant With Traditional NI-DAQ (Legacy) Driver
Updated Feb 2, 2018
National Instruments does not actively maintain this document.
  • DAQPAD-6020
  • LabVIEW Base
  • Traditional NI-DAQ
I have the Traditional NI-DAQ (Legacy) Driver installed. Why is the the DAQ Assistant missing in LabVIEW?
Note: This page is about NI-DAQ also known as Traditional NI-DAQ (Legacy). NI-DAQmx replaced Traditional NI-DAQ (Legacy) in 2003. NI strongly recommends using NI-DAQmx for new designs and migrating existing Traditional NI-DAQ (Legacy) applications to NI-DAQmx. Please review the Getting Started with NI-DAQmx guide for more information on migration.
The DAQ Assistant was introduced with NI-DAQmx 7.0, so it will not appear with the Traditional NI-DAQ (Legacy) drivers. You will have to use the Traditional NI-DAQ (Legacy) API to communicate with your DAQ device.
