NI-DAQmx and Measurement Studio Compatibility
Updated Mar 4, 2021
  • Measurement Studio Professional
  • Measurement Studio Standard
Programming Language
  • C# .NET
  • Visual Basic .NET
  • Where can I find compatibility or versions supported information for different versions of NI-DAQmx and Measurement Studio?
  • When using NI-DAQmx with Measurement Studio I experience errors, missing functions and libraries, devices failing to show up, and more.
The readme files for each release of NI-DAQmx specify which versions of Measurement Studio are compatible.
  • For information on examples that use NI-DAQmx and Measurement Studio, refer to Where to Find Examples in the NI-DAQmx .NET Class Library Help.
  • The DAQ Assistant is installed from NI Device Drivers media or download. You must install the NI Device Drivers  to use the assistant.
